Informazioni batteria AGM della CSM.
1 20 1
epsoncolor
epsoncolor
14/12/2008 1417
Inserito il 27/02/2024 alle: 16:02:18
Per informazioni
GENERAL PURPOSE
S E R I E S
www.npp-power.eu
UPS IT equipment
Security Medical
Equipment
Standard
NP12-100Ah
Valve-regulated lead-acid battery
AGM
Component Positive Plate Negative plate Container Separator Electrolyte Sefety valve Terminal
Raw material Lead dioxide Lead ABS (V-0 opt.) AGM Sulfuric Acid Rubber Copper
Characteristics Overview
Certification & Compliances
Dimensions & Terminal Type (mm)
Construction
Constant current discharge characteristics at 25°C
Constant power discharge characteristics at 25°C
NPP Power General Purpose series batteries are de-
signed with state-of-the-art AGM (absorbent glass mat)
technology, high-performance plates and electrolyte.
With excellent value and characteristics, this range is
suitable for all general purpose applications.
The above characteristics represent average values and can be obtained within three charge and discharge cycles. The batteries must be fully charged before testing. The
data in this document is subject to change without notice and become contractual only after written confirmation. Please contact NPP Power for the latest available version.
Copyright © 2021 Guangzhou NPP Power Co, Ltd. All rights reserved.
(Watts/battery)
(Ampere/battery)
Compliant to: EUROBAT, RoHS, WEEE’s and Reach.
Manufactured according to IEC 60896-21 / 22
NPP Power (Vietnam) Co.,Ltd
Lot A22.3, Road C4, Thanh Thanh Cong Industrial Zone,
An Hoa Village, Trang Bang District, Tay Ninh Province,
Vietnam
F.V/Time 10min 15min 30min 60min 2h 3h 4h 5h 8h 10h 20h
9.60V 218 168 101 61.8 36.5 26.3 21.0 18.0 12.3 10.2 5.40
9.90V 211 164 98.5 60.9 36.3 26.2 20.9 17.8 12.3 10.2 5.38
10.2V 203 158 95.5 59.3 36.0 26.0 20.7 17.7 12.2 10.1 5.37
10.5V 194 153 93.2 57.5 35.5 25.8 20.6 17.6 12.1 10.1 5.34
10.8V 183 144 89.7 55.6 34.6 25.0 20.0 17.1 11.7 10.0 5.30
9.60V 2354 1845 1128 705 423 309 247 212 147 122 64.7
9.90V 2284 1800 1105 694 421 308 246 211 146 121 64.6
10.2V 2190 1734 1071 676 417 306 244 209 145 121 64.4
10.5V 2095 1675 1045 655 411 303 242 208 144 120 64.0
10.8V 1978 1586 1007 634 400 294 235 202 139 119 63.6
Nominal voltage 12V (6 cells per unit)
Nominal capacity at 10 hours rate/10.8V (25°C) 100Ah
Capacity (25°C) 20 Hours rate/10.8V 106Ah
5 Hours rate/10.8V 85.5Ah
Terminal type T16
Torque 12.3±2.5N.m
Approx. internal resistance (25°C) 4.5mΩ
Dimensions
Length 330±2mm (12.99inch)
Width 171±2mm (6.65inch)
Height 214±2mm (8.43inch)
Total height (T14) 220±2mm (8.66inch)
Design Life
(stand-by)
JIS at 25°C 10 years
Eurobat at 20°C 10/12 years
Weight 29.50kg (65.04lbs)±3%
Nominal operating temperature 25°C±3 (77±5°F)
Operating
temperature
range
Discharge -15°C~50°C (5°F~122°F)
Charge -10°C~50°C (14°F~122°F)
Storage -20°C~50°C (-4°F~122°F)
Float charging voltage at 25°C 13.5V~13.8V
Cyclic charging voltage at 25°C 14.5V~15.0V
Temperature
compensation
Float charge -18 mV/°C/Block
Cycle charge -30 mV/°C/Block
Max. charging current (A) 30A
Max. discharge current for 5 seconds 800A
Self discharge rate (25°C) ≤3%/month
Battery container ABS UL94-HB V-0 optional
330±2
220±2
214±2
171±2
∅ 16
M8 x 20
T16
Rev. 140921-KK
No.67 Lianglong Road, Huashan Town, Huadu District,
Guangzhou, China
Email: info@nppower.com.cn Tel. +86 20 37887 390
Inserito il 27/02/2024 alle: 17:02:32
A parte che dai dati tecnici impressi sulla scocca esterna della batteria sembra essere Vietnamita e non Cinese.
A maggio dell'anno scorso ne ho acquistata una per raggiunti limiti di età di quella che avevo della Fiamm 100Ah, che dopo 12/13 anni stava perdendo la sua capacità di mantenere una tensione e carica costante per un tempo sufficiente.
Devo dire che sta lavorando bene e soddisfa pienamente l'utilizzo che ne faccio.
Modificato da eolo 58 il 28/02/2024 alle 16:21:25
